Gönderen Konu: Binek Araçlarda ESP Zorunlu Donanım Haline Geliyor  (Okunma sayısı 1824 defa)
Ynt: Binek Araçlarda ESP Zorunlu Donanım Haline Geliyor
« Yanıtla #25 : 06.May.2014 20:51:06 »
esp var la  :hişşt: :hişşt: :hişşt:
http://binekarac.vw.com.tr/jetta-donanim.aspx
Aracın tanıtım etiketinde fabrika çıkısı olan donanımlar yazar.
oradan bakabilirsin
donanımları buraya yaz..
Q1A;
gibi
http://igorweb.org/equidec/
decode tusuna bas.
ÖRNEK:
http://igorweb.org/equidec/howto.html
E0A = no special edition
1D0 = without towing attachment
5SL = outer left rear view mirror: non-spherical
5RQ = outer right rear view mirror: convex
1KF = disc brakes, rear
6FB = body-colored outer rear view mirror housings
1AT = electronic stabilization program (ESP)
3FA = without roof insert (standard roof)
1N3 = speed-related variable steering assist (Servotronic)
1NL = covers for alloy wheels
H6L = tires 225/45 R 17 91with Y tire width restricted to 219mm
4UF = drivers and front passenger airbag with front passenger airbag deactivation
4R4 = power windows with comfort operation andcircuit breaker
B59 = type approval Republic of Slovakia
3QT = 3-point seat belts with tensioner and height adjustment, front
4X3 = side airbag front with curtain airbag
4A3 = seat heater for front seats separately controlled
« Son Düzenleme: 06.May.2014 20:56:41 Gönderen: Admin »
  • İleti: 17650
« Yanıtla #26 : 06.May.2014 21:02:56 »
oradan bakabilirsin
Q1A;
gibi
decode tusuna bas.
ÖRNEK:
abi esp var poh atıyo arbama
Çevrimdışı AcMpi
  • İleti: 4422
  • Emekli Moderatör
  • *Şehir: AKSARAY
« Yanıtla #27 : 06.May.2014 21:03:24 »
oradan bakabilirsin
Q1A;
gibi
decode tusuna bas.
ÖRNEK:
bendekiler bunlarmış  :w:
X2F = National sales program Turkey
B0A = Component parts set without country-specific design requirement
D33 = 4-cyl. gasoline engine 1.4 l/92 kW 4V TFSI Base engine is TU0/TL1
G0K = 6-speed manual transmission
1AT = Electronic stabilization program (ESP)
8GU = Alternator 140 A
J0L = Battery 340 A (70 Ah)
C6S = Alloy wheels 6.5J x 16
HH7 = Tires 205/55 R16 91V
1G6 = Space-saving spare wheel
1NL = Covers for alloy wheels
8YM = Radio with CD player (high-end)
8L3 = Roof antenna
8RM = 8 speakers (passive)
8BG = Twin-headlight for driving on the right,with integrated high beam
8WD = Integrated front fog light
8TC = Rear fog light for driving on the right
2Z0 = Deletion of model designation
2B2 = Additional exterior noise suppression
5SJ = Left exterior mirror: convex
5RQ = Right exterior mirror: convex
QG2 = No possibility of activating service interval prolongation
0GG = Emission standard EU4
G40 = Front shock absorption
  • İleti: 17650
« Yanıtla #28 : 06.May.2014 21:05:32 »
garanti dediğin kazık lo :hiii: bakım dediğin bana 150 sana 600 e malolur  :hiii:  para tuzağı bu :hoho:
ben bilmez kışın 30.000 bakımından sonra garantiden zinciri değişti garanti olmasaydı 1400 küsür lira para bayılacadım :aaa: http://www.tempratipo.com/forum/index.php?topic=27508.0
« Yanıtla #29 : 06.May.2014 21:11:59 »
eee bizim garip tempratipo canlar vb nolcek şimdii  :mm: :mm:
« Yanıtla #30 : 06.May.2014 21:13:52 »
Müzeye  :hiii:
Esp olmayanları atamazlar.. 0 araclara mecbur koymuslardır
« Yanıtla #31 : 06.May.2014 21:15:52 »
Müzeye  :hiii:
harbi başkan nolcak şimdi bu zımbırtısız bınlerce arac.yoksa bu yasa o tarıhten sonra üretılen araclarımı kapsıyo   :s20: :???: :???:
  • İleti: 17650
« Yanıtla #32 : 06.May.2014 21:17:39 »
vercen 1500 ü esp taktırcan :hiii:
Çevrimdışı AcMpi
  • İleti: 4422
  • Emekli Moderatör
  • *Şehir: AKSARAY
« Yanıtla #33 : 06.May.2014 21:19:40 »
takılamaz :w:  sen koş bi arabaya bak gel. 1at yazıyomu :hiii:
  • İleti: 17650
« Yanıtla #35 : 06.May.2014 21:21:45 »
bakmaya lüzum yok esp var arabada denedim :hoho:
  • İleti: 17650
Çevrimdışı AcMpi
  • İleti: 4422
  • Emekli Moderatör
  • *Şehir: AKSARAY
« Yanıtla #37 : 06.May.2014 21:22:28 »
tcs dir o :cc:
  • İleti: 17650
« Yanıtla #38 : 06.May.2014 21:25:51 »
tcs dir o :cc:
hadi len standart donanımında var arabanın daha tcs diyo Ford focusmu bu  :kötü:
« Yanıtla #39 : 06.May.2014 23:11:33 »
ESP mecburiyeti sadece sıfır model araçlarda uygulanır, mevcut arabalara uygulanması zor.
« Yanıtla #40 : 07.May.2014 18:55:55 »
Benim arabadaki ABS sistemi ve takmaya çalıştığım lastik basınç sensörü muayeneden geçer mi acaba?
  • İleti: 1231
« Yanıtla #41 : 07.May.2014 20:56:25 »
ABS orjinalinden beri olan birşey neden geçmesin ki? Sonuçta siz eklemediniz. Lastik basınç sensörünü siz yaptınız ama güvenliği olumsuz etkileyici birşey değil. Hatta onu anlamazlar bile.
SalihGezerer
« Yanıtla #42 : 08.May.2014 01:56:39 »
bi tipo aldım burnumdan geldi şimdi 1991 model olan tipoma esp ve aps mi taktıracaz yoook bide arka camlarda otomatik olacak neymiş yeni çıkan arabalar gibi yolu tutacak direksiyonda yolu tutan benim azrailde olsa ezerim :D   :crash:
